Originally posted by MaxTheKnife
How big an old boy are you anyway Matthew?
True. But if you like recurves, you can acquire equipment to sharpen them. Jig type, Spyderco / crock sticks, bench grinder for big knives, etc.Originally posted by matthew rapaport
But what about the disadvantages? Difficult to sharpen on a benchstone (even a relatively narrow one using a jig IMO);
With something like the 710, you can use the front/belly for pushcuts, reserve the recurve for cardboard, rope, vines, etc. As far as game prep, there are indeed better knives, and if I thought I was going to prep game (fish, deer, squirrel/rabbit), I have several knives optimized for each of those. 710 would work fine on game in a pinch.Originally posted by matthew rapaport
no good at push cuts where the whole edge must meet the cutting surface at the same time as in dicing vegies; not very good for scraping if you want to use all or most of the blade behind the belly (taking scales off fish, hair off hide, or plaining wood where the advantages of the recurve actually become disadvantages);
Indeed, there is little use for recurve in the kitchen, but I think you could slice meat and bread and apples in the field just dandy compared to the alternative, using your hands or a rock or something, if all you had was a 710. I usually quarter the apple first before removing 4 pieces of core w/ U-shaped cuts anyway.... I'm nitpicking....moving on.Originally posted by matthew rapaport
not good for thin slicing meat or bread because the center of the belly hits the cutting surface before the rest of the edge has cut through what ever it is you are slicing; or for any application where you must turn the knife (change direction of the cut) with the tip embedded in the substance (for example coring an apple).
Overkill, maybe. But not inferior. Mild overperformance isn't a problem. I understand Matt has outlined places where recurve is a disadvantage also.Originally posted by matthew rapaport
Add to this that the recurve only comes into its own when the substance to be cut is non trivial - for example thin cardboard is so easy to cut with any knife that the gut-hook effect while present is overkill.
Indeed, there are plenty of good utility folders that are fine for self defense and balanced enough to not piss you off afield. Spyderco Starmate, Benchmade AFCK 800, Spyderco Wegner, even MT LCC with so little belly is a nice knife. Some like Spyderco Military in this sort of group/application also. I like it pretty well myself.Originally posted by matthew rapaport
So for me (again, just my opinion), taking all of this into account, the recurve makes little sense and I don't buy them.
And if you want extremes, find an Emerson Commander w/ good lockup. It has a kinda fat belly, but that won't prevent a thrust from entering unless you hit ribs perpendicularly or something. Most any knife can be thrust into soft materials with ease, even through ballistic vests. They focus tremendous forces on a tiny surface area or point, high sectional density is one term used.Originally posted by matthew rapaport
If the knife is primarily intended (and sold) for "self defense" as many "tactical knives" are, and in addition, your self defense style favors slashing (the recurve has no advantage in thrusting), then by all means buy a recurve.
...and repeating, here are some of my other favs...stuff still owned and not sold/traded: Spyderco Starmate, Benchmade AFCK 800, Spyderco Wegner, MT LCC, Spyderco Military.Originally posted by matthew rapaport
If, on the other hand, the knife you carry might have to do any of the chores listed above and/or you don't spend all day pulling knives through thick cardboard or sawing through thick rope, then consider a non-recurved blade.
