Red Horse Chopper & War Pig in stock!
Feedback: +1 / =0 / -0
Red Horse Chopper Frame Lock, D2 Stonewash 3 1/2 in.Blade, Titanium Handles
Our Price: $447.95
Free shipping on all USA orders over $99.00
http://www.knifeworks.com/redhorsec...sh312inbladetitaniumhandles.aspx#.VAgwpRsg_IV
Red Horse’s premier Tactical & EDC folding work knife, The Chopper is a knife designed to take extensive amounts of abuse. The 4.5 inch long 3/16th thick all titanium handle is ergonomically designed to be comfortable for every task and the 3.5 inch blade is 3/16th thick. The blade utilizes a Wharnecliffe style flat V ground edge for maximum cutting power. The over-sized thumb disc is custom machined in house out of 3/8th thick titanium.
Specifications
Blade – 3.5 inches long and ¼ inch thick D2 tool steel with a flat V ground Wharnecilffe style blade. The spine on this blade has been hand contoured then stonewashed/satin finished.
Handle – 4.5 inches long using two 3/16th thick titanium scales that have been hand beveled and then stonewash finished for durability.
Weight – 7.52 ounces
Red Horse War Pig Frame Lock Folder, D2 Stonewash 3 1/2 in.Blade, G10 and Titanium Handles
Our Price: $397.95
http://www.knifeworks.com/redhorsew...hbladeg10andtitaniumhandles.aspx#.VAgv4xsg_IU
The War Pig; a stout over built folding EDC knife designed for hard field use. This knife was designed for the military operator and LEO professional in mind. It features a 3.5″ long and 3/16th thick D2 blade heat treated to a 58 Rockwell hardness and has a V grind style profile. The main cutting portion has a prominent re-curve for added cutting power while the tip of the blade is suited for more nimble cutting. The wide profile ensures structural integrity in even the worst conditions. The frame-lock construction features a .187 inch thick titanium lock side and a .25″ thick G10 scale with the overall handle length measuring at 4.25 inches which has a hardened stainless insert for the bearing action. The handle is designed with two large finger grooves to insure against slippage in any environment. This knife features dual flipper and thumb-hole style opening actions.
Specifications
Blade – 3.5 inches long and 3/16th inch thick D2 tool steel featuring a compound grind consisting of a hollow V ground belly and convex ground tip for maximum strength and durability along with a stonewashed/satin finish. This blade is built for extreme field work.
Handle – Lock side features a 3/16th thick titanium scale that has been stonewashed for durability. Non-lock side features a 1/4 thick G10 scale that has been hand contoured and a hardened stainless steel insert to accommodate bearing action.
