- Dec 19, 2002
Red Horse Hell Razor Liner Lock, 154 CPM Stonewash, G-10/Titanium Handles
Our Price: $497.95
http://www.knifeworks.com/redhorseh...tonewashg-10titaniumhandles.aspx#.VO3JJxvwvIU
The Red Horse Hell Razor is our tribute to the Americana icon of the straight razor. The Hell Razor is far from your grandpas old shaver, this is a 21st century tactical and EDC knife. The Hell Razor pays homage to the classical lines of its ancestor but uses modern knife making materials and design including a liner lock system and detente system to keep the knife close in your pocket. The 3.75 inch long and 5/32 CPM154 blade features a Wharnecliffe curved blade that can be used for both slashing and thrusting. The handle is an impressive 5 inches long and fits comfortably in either saber grip or reverse grip.
Blade 3.75 inches long and 5/32th thick 154CPM steel featuring a stonewashed/satin finish. Blade features a flat ground V grind style with a chisel final edge. The spine is hand contoured and is styled after a traditional straight razor with a large curve for increased cutting power.
Handle 5 inches in overall length with two .100 thick liners that have been stonewash finished and two 1/8th thick G10 scales that have been hand contoured and shaped.
Weight 6.4 ounces.
STANDARD EQUIPMENT:
* Titanium Liners
All liners and frames are constructed using knife maker grade 5, 6AL4V titanium that has been precision ground flat.
* Carbidized Lock Faces
All RHKW knives feature carbidized lock faces which prevent premature lock face wear as well as insuring a smooth unlocking motion. This is achieved by essentially welding a very thin layer of tungsten carbide to the face of the lock bar. We believe that the Devil is in the details and this is one fine detail that ensures a solid knife for ages.
* Bearing Action
All RHKW knives utilize Alpha Knife Supply precision stainless bearings for the opening and closing action. Constructed of stainless steel cages and 440C ball bearings, these are the highest end method of action that is unmatched in quality and durability.
* Precision Pivots by Alpha Knife Supply
Made of 416 stainless steel, vacuum heat-treated to 42RC and machined to .0002 tolerances, these are the finest pivots available today.
* Precision Stainless Stand Offs
All RHKW knives come standard equipped with stainless steel stand offs, machined within .0001 of an inch to ensure proper construction. These stand offs save weight, allow easy cleaning and easy field striping/reassembly.
* 154CPM Steel is Heat Treated to 59RC Hardness and Cryo-Treated
All RHKW blades are heat treated in house in small batches for quality control in our digitally controlled kilns. Each blade is then tested for proper Rockwell hardness. This is the highest form of quality control in the knife world.
Our Price: $497.95
Weight 6.4 ounces.
STANDARD EQUIPMENT:
* Titanium Liners
* Bearing Action
