Reduced-Acebeam UC15 Flashlight
Feedback: +19 / =0 / -0
While marketed as a "keychain" light, it is a bit large for that but a very interesting light. Operates with 2-AAA batteries (or 10440s) for up to 1000 lumens. It also has UV and Red lights which are quite bright.
The earlier versions did not have a lockout function but this is the newer version which does have lockout.
Complete with all original packaging and will include 4 - 10440 Soshine batteries.
Asking $50>$45 OBRO shipped and PayPal'd. Pocket dangler and battery case not included.
Product description from company:
LED: 1*Cree XP-L /Nichia 276A 365nm/Cree XPE-R2 LED
When using 2*10440 batteries
Moon: 5 lms, 46h
Low: 140 lms, 2.4h
Mid: 330 lms, 1.1h
High: 600~200 lms, 4min+30min
Turbo: 1000~200 lms, 1min+46min
Strobe: 1000 lms
Red: 1.5h
UV: 1.2h
Battery Indication:
Indicator Lighting Green > 3.3V
Indicator Lighting Red among 3.1-3.3V
Indicator Lighting Red&Flash < 3.1V
Turn off automatically < 2.7V
When using 2*AAA (Alkaline/Ni-MH) batteries:
Moon: 5 lms, 37h
Low: 30 lms, 7.5h
Mid: 60 lms, 4h
High: 105 lms, 2h
Turbo: 250 lms, 1.1h
Strobe: 250 lms
Red: 1.6h
UV: 1.3h
Battery Indication:
Indicator Lighting Green > 1.05V
Indicator Lighting Red among 1.05-0.95V
Indicator Lighting Red&Flash < 0.5V
Working voltage: 0.9V - 4.2V
Max Runtime:37h
Max Beam Distance: 107M
Peak Beam Intensity: 2880CD
Impact Resistance: 1M
Water Resistance: IP54
Size: 66.10mm (Length) x 29mm (Width) x16.3mm (Thickness)
Weight: 39g (without battery)
Aircraft grade aluminum body structure
Premium Type III Hard Anodized Anti-abrasive finish
Stainless steel king ring connector
Ultra-clear tempered glass lens with anti-reflective coating
Mini Key Chain Light is one of your indispensable companions when daily use,hiking, reading,searching and so on.
Note: Low battery warning when red light indicates flash.
