@Me2,
The count values are directly related to the surface area and magnification. So a higher count value does not automatically give a higher ASTM grain size number, the conversion factor has to be taken into account. It is best to look at the count values at the sample's photograph, the magnification and conversion factor are given there in the table. The ASTM grain size number was higher on the "as forged" samples, the normalizing lowered it.
My teacher told me the best practice was to go for pearlite formation only. That's why I didn't want any air or plate cooling, I needed accurate temperature control with the tooling I had. So I decided to do it all inside the oven where a TC was mounted. My teacher told me it was very important to enter the pearlite nose as early in time and as low in temperature as possible. In other words, enter the pearlite nose left-under. I think a salt pot might go more in that direction. It is important to go for an isothermal situation. So I kept the samples at 550 degrees Celsius for a few minutes (can be seen in table 2; Additional pearlite formation time) to make sure the pearlite formation finishes. After that I would climp up again and make a new cycle.
I didn't want to form bainite or martensite. I think forming martensite might give cracking problems. But if you can tell me advantages of going for these phases, please let me know.
@stezann,
Thank you!
Interesting. I suppose with carbides you are only talking about Fe3C? So you deliberately let the grains grow for a while pretty high in the austinization temp to go for a more even grain distribution? Do you perhaps have some information about this online? I think it is really interesting what you write about the ratio between grain boundaries and carbides but I would like to read some more detailed information about it.
@ mete,
I believe dealing with carbides in a martensite matrix is done by tempering? At these low temperatures I think you can't really make any changes to the grain size any more. What do you mean?
I haven't made measurements of the carbon content between the layers. It would be interesting though, but I'm pretty sure it has leveled out evenly at these thin layers, and taking all the forging time into account.
