- May 27, 2009
Thanks
it's a quite easy DIY project !!I'm suprised more people don't do it !
I have another question for those in the know. When blasting screws, do you only do the heads or the entire screw? I think doing the entire screw will mess with the spiral? How does CRK do theirs? I have only seen the bead blasted screws when they are already in the knife, not before they were installed.
Don't blast the threads ! Stick them into a piece of cardboard and only blast the heads of the screws
That is what I was thinking. I dont have a machine or anything but this info is good to know before one tries anything. Thanks for you help.
Ok. My final question I just thought of: When one blasts the Ti is one actually removing the Ti, or is it like a coat one puts on?
I found this definition but dont know if it can differ from other types of sandblasting: A surface treatment used to remove material by using air to blow sand or other grit at a workpiece.
If this is true then I can understand the need to use 'finer grain' sand or abrasive and lower pressure to minimise the amount of material taken of?
They use the term remove because it's used also for removing paint and rust from metal
If you would, please explain your set up. Safety equip., where you do your work, amount of mess, part prep, etc. The reason I ask is I have thrown around the idea of doing something like this several times. I have looked at several of the blast cabinets, but always thought they would be too big and I couldnt justify there space and cost for just a few projects. Also, all the ones I have looked at say NOT to use sand due to health risks. I think the projects you did look outstanding. I have several Sebenza clips that could use this traetment and I probably could find a few more knifes to experiment on!
All I used was a gravity fed gun with a small compressor and plain old sand!
