Thanks for reminding me. I will use the spatula blade on my Dr. to sort my pills.
BTW- should I be stropping the edge of my spatula blade, and if so....What grit?![]()
OK, I am going to fess up. I bought a couple of belts at a thrift store, gorilla glued them to some pine 2x4s cut down on my table saw, and applied compound. The green worked in ok at first, but now, the leather has frayed and I do not have a good smooth surface. The white jewelers rouge would not take at all in a uniform way due to the cheap thrift store belt. I will now be rethinking my strops. Wider than I did before, and good quality leather from Jantz that will stay smooth and not fray or get bumpy. I have some real nice oak planks to add an upgrade. Wisdom is not achieved by walking through a door, but by walking a path......
Remember to compress the leather before you mount it onto the boards. It's easy to do and makes a big difference in how the strops perform. Wet it down the same way you would for molding a leather sheath, then roll the hell out of it with a heavy roller. The finest old barber strops were made using horsehide that had been 'boned' by hand for several days! (That's rubbing it and compressing it in some fashion with a rounded tool. This brings the silicates to the surface of the leather.) I haven't been able to find any of these being sold new no matter how hard I've searched. I can find some horsehide strops (cheaper to buy the whole horse!) but none that have been boned into 'Russian Leather.' I have an old one, but for my purposes cow hide works just as well. If I shaved with a straight razor I'd certainly use the horsehide. (I haven't shaved since my date of discharge 40+ years ago....)
Stitchawl
Good advice but it would be a useless step if the leather was pre-finished and compound was to be applied.
Ok, so I have 3 flavors of strops....White for coarse, green for fine, and Stitch's old school boned pseudo horse hide from cows plain leather. I am puttin a slope to my learnin curve. I will be makin all 3. Unless, of course, I need a transitional grit somewhere in between.....Uh oh, not again...
Just a segway, when my wife got home tonight, she could see that I was distracted. "What is wrong dear?" I replied, "My strops are not holding their compound honey,
I give God a lot thanks that I am able to worry about stuff like that. I am hugely blessed.
No mess and it works better http://www.knifecenter.com/kc_new/store_detail.html?s=DMTDPK
DMT makes some good products. :thumbup: I keep their Aligner in my backpack and use their Diamond card with it, just for touch-ups in the woods. Not a particularly polished edge but fine for bushcraft. But for diamond paste I like to use the .25 micron stuff on a smooth leather strop. I don't know if DMT sells that. I get it from other sites.
Stitchawl
That's how I was before I got the DMT paste using the 6,3,1 micron DMT paste makes a big difference in finished sharpness, its amazing how much sharper the edge is by the time you get to the 1 micron. Try it out you might find yourself not using 0.25 anymore unless your like me and have a sharpening problem.![]()
Why don't you just get strop leather instead of doing all that work?
I like handamerican leather found at woodcraft.com and the peices you can order for the JRE convex sharpener are awsome for use with compound. No work is needed for these peices of leather and you can get a lot of it for cheap. You will like the diamond paste after the first time you use it you will wonder why you ever used anything else, better polish, sharper edge....what's not to love.
Almost forgot, MDF seems to work the best with diamond paste leather is good too but seems to work slower.
its a little hard adjusting to using MDF as a strop because you must keep the exact angle. should not be a problem for you because your perfect angles made by the edge pro help with "locking" the bevel to the surface, you'll know what I mean when you use it.
