- Jun 11, 2006
So I spent a good chunk of the day driving down and back from Salem’s shop today. This gave me lots of alone time to think which is not allways a good thing. On the way down I had been thinking about the possibility of building a manual drop hammer with big dies just for setting the welds on Damascus stacks. My press is quick enough that it can get away from me and take way to big of a bite on the first weld heat. And with me trying to go fluxless with larger billets I needed a way to gently tap them home quickly. After spending a day down at his shop and getting to run his monster of a hammer I knew I needed somthing similar. But on the way back I started thinking about my press and how I could bump the speed and drop the tonnage to a safe tap,tap tonnage. Not wanting to make it a hammer per say. Just somthing that can get in and out quick and get the welds set. Right now I’m sitting at 1.5”/sec at 24tons. As I’m driving I remember somthing I came across when I was researching my press build called regenerative hydraulics. Basically in a nut shell you connect both A and B ports of the cylinder togather and hit it with the pressure. What you get is a force difference twords the side with the rod.
At my 3000psi this difference is 9425psi. That’s not a bad amount of force to just introduce the hot layers to each other. The way it works is when you pressurize both sides at the same time the oil moves from the rod end to the cylinder end. All you have to do is makeup the difference in volume with the pump. This volume difference is the volume that’s occupied by the 2” rod. At my pumps rated GPM of 6.94 it would move that top die at a rate of 8-8.5”in/sec at the 9425pounds. A selector valve would be built in so I can go from one mode to the other in the fraction of a sec. To give you an idea the kind of speed we are talking about here. If I set the upper limit switch around 1” off the stock it would close that gap in around a tenth of a second. A full cycle rate with the limit switches would be less then a sec. the solonoide switching time is around .1 and down is .125 and up is .5 so that’s .825 total. Even at 1sec that 60 presses per min. I’m not sure about hose diameters and how that’s going to factor into it but if I’m doing short strokes it should not be to much of a problem. Any way enough of my rambling, it’s time for bed.
