Sale Terms:
This was given to me as a gift, which I then passed to a friend as it is a clone of an Olight S10. Friend gave it back as they couldn't get used to the UI. Tint is warm to neutral (3800K-4000K). Can use either a CR123a primary or 16340 rechargeable battery (now includes an AW IMR 16340 rechargeable battery). Some light anodizing wear. Includes pocket clip, box, and carrying pouch.
UI
From Off: Press and hold to turn on in last memorized mode.
From On: Single click advances modes from ultra low (not really an ultra low just what they call it) to low to medium to high, back to low, etc.
From On: Press and hold to turn off.
From Off: Double click to turn on in Turbo (also works at any time light is on)
From On: Single press to go to last memorized mode.
Flashy modes (non-memorized)
From Off: Triple click to turn on in Strobe (also works at any time light is on)
From On: Single click advances modes from strobe to beacon to a fast SOS, back to strobe, etc.
From On: Double click to return back to constant output modes
8) Olight S35 Baton Neutral White relisted
This was from the Olight Holiday Hiker set (a limited edition release) a while back. This light is used and has some marks on the body as well as the tail end (see slight dings in photos). Has a neutral white XM-L emitter (green board, old school now!) and runs off of 3xAA batteries. UI is single click to turn on, single click to turn off. While light is on, press and hold to cycle through low, medium, and high. Double click (from on or off) to access strobe. No original accessories included as I do not recall if any were included but I no longer have the packaging, but I will include 3xAA Tenergy Low Self Discharge batteries.
10) BLF A6 Special Edition Neutral White relisted
This one has some use and carry. Very interesting UI and bright for a single cell (18650) light! Tint is 4000K neutral white XM-L2. Includes original box, spare o-rings, lanyard, and spare boot cover.
Full disclosure: Pill and retaining ring are loose and cannot be removed or tightened from what I can tell (and from what I have tried). It is almost as if the retaining ring inside the head was threaded smaller than should have been. Cannot tell why it will not back out as it just spins and spins in place no matter what direction it is turned. This doesn't appear to affect the function of the light as it turns on and works as it should, just something I noticed when I removed the head for cleaning once before. Make sure if both the head and tailcap are removed (if cleaning for example), that they are placed on the same ends of the body that they were removed from. If they are switched to the opposite ends, the light will not turn on.
--SOLD--
4) Olight S Mini Bead Blasted Titanium [Sold on another forum] $65
Fondled but not carried. Limited Edition in neutral white (5000K). Includes an Olight 16340 rechargeable battery - note that the polarity is reversed and the positive end goes towards the tailcap in this one. Threads are par for the course for Titanium and are a bit gritty, even with lube. Applying downward pressure when screwing on the tailcap helps some in this respect. This thing is tiny! Can run off of either a CR123a primary or 16340 rechargeable battery. UI is nice with a moonlight mode available from off. Heats up pretty quick on turbo but there is a timed step down so it doesn't get too hot. Includes original packaging.
9) Fenix HL15 [Sold to fogdart] $30
NIB and a very nice headlamp. I bought 2 for me and this was a backup. The one pictured outside of the package is my personal HL-15. Neutral white tint with four output levels: low, medium, high, turbo, and 2 red mode outputs: constant low, and beacon. Both can be turned on simultaneously. Runs off of 2xAAA batteries. Will come with a second set of alkaline batteries from my used HL-15 as I do not like to use alkaline batteries in my lights, and 2xAAA Tenergy LSD rechargeable NiMH batteries.
11) Armytek Wizard Pro Wide XM-L2 Warm [Sold to fogdart] $65
Used and carried and shows some light wear, but a great headlamp. This is the first version and has options that are no longer available, such as being able to set it to tactical that gives the switch a momentary function like a forward clicky. It also has a voltage meter readout available when in the flashy modes. Tint is listed as warm but is a nice neutral white. The honey comb diffuser that Armytek uses is excellent in giving the beam a nice and even spread. Photos of the manual are included below but I will also include a link the the .pdf of the manual for full detail. Includes box, headlamp, pocket clip, spare o-rings, and original manual.
Full disclosure: I could not locate the top strap for the headband but it still works with the single band that wraps around the head.
- US Shipping only
- First Class Shipping unless otherwise indicated
- Paypal Purchase of Goods Option (no gift payments please)
- I reserve the right to refuse sale at my discretion
- Not looking for trades
UI
--SOLD--
