Before the stiches? We don't need no stinkin' stiches.
large thumb stud + loose blade screw + tip-up position in pocket = 4 stitches
i am rethinking tip up for my recently finished knife-kits DDR2
This is a subject I hold close since I've also had some bad experiences. I don't think it has anything to do with tip up or not. You really think it's any better for a blade to open in your pocket tip down? In my case it just came through my pants pocket & I had a needle pointed 4" blade sticking straight out from my thigh- it could have just as easily lodged straight into my thigh.
A pivot screw that's adjusted slightly loose shouldn't matter either, IMO. I mean, we're not talking about friction folders, are we? Don't we design folders with all kinds of springs, detents, and other mechanisms precisely to keep the blade closed in your pocket? And don't you think they should work all on their own?
A thumb stud that's too big, or stands well out from the handle material where it will always get caught on the pocket, I do see as a problem.
I've tried the superglue trick a time or two, but I can't get it to hold while the skin is wet/bloody. Is there a trick?
Clean the wound well, inside and out. Don't be a pussy, just do it. You don't want to glue up an infection and have to wait two days for the super glue to come off. I use soap, then alcohol. Man up.
