I e got the 1x30 harbor freight sander as well. I use it mainly for reprofiling. It take a little getting used to but once you figure it out, it's fantastic. I use it to sharpen friends/coworkers knives all the time. And the majority of them are plumbers. So their knives cut cardboard, wire. Anything a knife wasn't designed to cut 😀 If it's REALLY bad I'll use the 120 grit belt first. But usually I'll do a 320 grit and then just crisp up the apex with the sharp maker rods. You get scary sharp in less than 5 minutes. If I'm feeling froggy, I'll use my 800 grit belt and then finish off on the buffing wheel for a nice mirror polished edge.
My best advice is to start with a knife that you aren't really attached to. I also lay my sander on its back with they belt running away from me. That way it sort of mimics using a bench stone. It uses the same muscle memory for getting the right angle on the blade
