I disagree on using Philips and slot head bolts. The Torx or Allen head bolts/screws are more professional looking, and will stay in good shape longer. Also, no one would likely need to disassemble a knife handle in the field. Torx head driver bits are in most multi-tip hex drive packs. and they are available from most tool places. Most folks who work with knives and guns enough to request a removable handle probably already have them, anyway.
On autos with the speed adjustment being the pivot tension, I give the owner the proper size Torx bit to fit the pivot. It costs me about a buck, and assures the owner will adjust the tension as it wears in. A complete torx driver set for knife work costs about $7. I have given those away with a knife too.
You don't need, or want long screws. You put inserts in the tang that the screws fit. The insert is what the scales slip on, and the screws lock the scales down snug. The insert is the strength bearing part. When fitted right, the insert comes up almost to the head seat of the hole in the handle - .250" long screws are plenty long enough for any knife.
Several of the knife suppliers who deal with folder parts sell the screws in several metal, head types, and sizes. Knifekits.com has a lot. I find that 4-40 and 6-32 work well. You can get the tang inserts from them, too.
