Hi Guys,
I posted a week or so ago about tapping a 4-40 tap into Titanium as I was having trouble with it ( the Taps kept Snapping ) Some of you guys suggested that I use a larger drill ( a #41 instead of a #43 ) this has worked well. However after tapping a few holes, I must have become a little excited and I accidentally snapped another tap which is now wedged into the Titanium in a BIG way....
I noticed some of you guys mentioned that Ferric Chloride would be a solution to removing the taps from the titanium so i have been looking all over the place down here in Adelaide South Australia, and I think its fair to say hardly anyone knew what it was, and those that did know, knew not where to get it. Are there any other more common acids that might do the same trick? Alternatively I was wondering if I should try and drill the taps out with the same size drill bit ( #41 ), as I have sanded the stuck tap down and it is now flush with the Titanium handle - Any suggestions? I would really like to save this Titanium handle.
Thank you for your help
Regards
Suva
Regards
Suva
