Remove Handle from seal pup elite
I have a seal pup elite that I would like to make a custom handle for. Could someone please recommend a way to remove the factory handle. Any help would be much appreciated!
Not sure but there was a review of the Seal Team Elite where the blade was destroyed and the tester cut the handle off to show the tang. I believe it was in this forum.
Edit: found the link... Here
I used a belt sander to remove the handle of my Seal 2000. Grind off one side, then the other side will pop off.
Lock the handle in a vice and use a hack saw from the top down.........you will know if you hit steel, just move it over a bit.
Robbie Roberson ;)
I don't think a chisel would work. The handle on these knives is pretty tough.
Thanks everyone for your suggestions. I don't have a belt sander so I think I'll try a hacksaw & coping saw first as suggested.
