Oh contrere gb. I took it as good advice and appreciated:thumbup:
Gasoline also readily dissolves cosmoline. No scrubbing necessary.
On hammer handles (mainly ash, but a few hickory) I have used a coat of tru oil followed by paste wax with good results. Might not hold up out doors (axe or hatchets) though.
Works fine for gunstocks which see plenty of outdoor usage and handling. I like Tru-Oil because it is mostly a surface treatment and is very easily repaired.
This is a great thread. There is a ton of information in a couple pages.![]()
The "40" is because it took them 40 times to get it right.
Couldn't agree more! I've tried at least a dozen different oil finishes over the years. Sadly, my favorite has been discontinued. I still have an unopened quart that should last the balance of my fishing days. When I do a stock it takes about 30 or more coats to get my desired results. It's a thinner oil but, penetatrats deeply. Each coat is sanded in with several coats starting with 320 up to 800 or 1000 grit depending on the desired results. I sand into a slurry and remove excess by wiping across grain with the least absorbent brown paper towels available. By the time I'm done they have a perfectly smooth finish with luster and a depth you can reach into. I use a few drops of Cobalt drier with each batch needed for an application. This cuts the drying time drastically so that several coats can be applied in one day. These are certainly not secrets and you may be using the exact or similar technique I'm just sharing if others may be intetested.
