I'm not setup for sandblasting but im most likely going to hand sand. It sounds like it's going to be drawn out through a couple days.
The DLC bond can be weakened with a soak in hydrogen peroxide. I forget where I read it, but it worked for my ZT770cfM4.
I pulled the blade out of my knife and soaked it in a glass filled with hydrogen peroxide for 1.5 - 2 hours. I kept checking on it, but it just sat there and every now and then it would release a gas bubble or two. Afterwards I hit it with some 2k SiC sandpaper under running water. That left me with the impromptu blackwash you see below.
With how the ridges polished up after a minute or so of sandpaper, I would think the soaking is close to what was needed.
I sanded by hand and without a block so I would only soften it all around and polish the highs.
If you were to use a solid backer, I am sure you could get near all of it off relatively easily.
I think the soak did help. I tried hitting it with the 2k prior to the soak . . . they [bubbles] were definitely being generated from some form of reaction.
I've contacted you about that in the past...but didn't end up trying it on the knife I was focused on at the time.I think the soak did help. I tried hitting it with the 2k prior to the soak to see if there would be much of a difference. It scuffed it up, but didn't remove anything significant.
that's cool !
I've always thought of hydrogen peroxide as such mild , pour it on cuts in my skin, stuff.
From now on I will look at it as armor plate dissolving, heat shield melting, magic elixir .
I only sanded a small portion. The way that I looked at it, why sand the whole thing if a small spot would be easier and give me the information I sought.I've contacted you about that in the past...but didn't end up trying it on the knife I was focused on at the time.
Looking at the quoted statement, I find myself wondering if the "pre-sanding" is a key step. Would the same effect have been attained without it, or might the unmarred DLC have withstood the challenge? I've still got my 0770cfm4 sitting new in the box...maybe I'll do some experimenting one rainy day this week.
