Removing Grinding gunk from Giraffe bone
Erin Burke
KnifeMaker...ish
Rookie mistake. While grinding the stabilized giraffe bone scales on my latest knife, I ended up filling up the marrow pores (only visible near the guard) with grinding gunk. Here's a photo.
Anyone have any good ideas for removing this material?
Here's what I already tried:
  • Vacuuming it out
  • Using a magnet to pull the metal grinding gunk out
  • Flushing with a syringe of alcohol (maybe not enough pressure)
Once I remove as much of the black as I can, I plan on mixing up some white epoxy with using the bone dust and filling in these pores before final sanding/polishing.
Thanks in advance.
Erin
I had the same thing happen on a Whitetail antler I used as a handle (except it was buffing compound not grinding gunk
) and I used a tooth brush to clean it up.
Hah... that's so easy it just might work. :D:thumbup:
I'll give it a try.
Erin
Using a toothbrush, and a paste made of Ivory soap and baking soda will remove most stuff.
I use plain colgate toothpaste.And a soft toothbrush.
Stan
Compressed air works also. After you get the gunk out I'd forget the dust mix and just fill with super glue.
