- Apr 12, 2009
^^Awesome!! Good to hear it's all tidy again. :thumbup:
David
David
Keep the knife CLEAN and DRY, first and foremost. Mineral oil can't, by itself, speed up rusting issues UNLESS the oil is trapping dirt, salt, acids or moisture against the steel. Same holds true with any other oil or 'protectant'. Mineral oil is completely non-reactive (chemically inert), so it isn't capable of causing rust by itself.
David
You are describing it in more technical detail than my limited understanding of science can summarize, but ultimately the end results are generally the same: in some cases, surfaces treated with mineral oil sometimes rust faster than the same surfaces that are just washed and dried. To my [limited] understanding, the scientific reasoning of mineral oil is generally under the basis of displacing oxygen and water and hence slowing the process of oxidation. As you noted, it lacks others additives and other particles expedite oxidation. However, it is almost impossible to avoid these on a knife that lives in a pocket, goes all over the place, and is used for almost anything in a world where there are particles in the air which in and of themselves can expedite rusting. And as a wet lubricant, it suffers from the issue of accumulation, with no additive to interfere otherwise. Even if someone can keep it clean and free from accumulation, it evaporates at a rate that limits its practicality greatly. Even on cutting boards it tends to evaporate really quickly and so quickly that I've moved to a cream that is part mineral oil and part beeswax for a little better longevity.
Mineral oil doesn't promote rusting. It doesn't evaporate quickly, either. The main lubricant in most oils is mineral oil.
Mineral oil gets rubbed or washed or scrubbed away in use, true. So will every other lube or protectant ever made. In porous materials, it'll sink in over time. It doesn't evaporate, however (unless heated to extremes). The oily/greasy film left on lubricated machinery for years & years is the unevaporated base 'mineral oil' left over after other solvents and additives have evaporated off.
And the 'accumulation' issue is true with any petro-based lube or protectant as well (and contradicts the evaporation theory; it couldn't accumulate if it also evaporates away). This is why I pointed out CLEAN & DRY as the primary and most effective means to minimize rust. A knife that gets cleaned and re-oiled as needed will also have the old oil cleaned off and re-applied, and the accumulation issue is rendered moot.
As Bill has mentioned, mineral oil makes up the primary lubricating ingredient in the overwhelming majority of products made for such use.
David
