- Aug 11, 2001
The way I repaired the failing rolling lock on the SIFUS that I own is as follows:
1. Remove only the blade from the handle by unscrewing the pin that holds the blade in place. Be sure not to lose the 2 nylon spacers on either side of the blade where the removed pin passes through the blade.
2. Use a metal cone shaped file with diamond bits embedded into the metal cone and use 150 to 200 individual strokes to file down the rear of the notch in the rear of the blade that the rolling pin rolls into.
3. Reinstall the blade into the handle and you will find that the rolling locking pin will fully roll into the notch in the rear of the blade. In other words, the rolling locking pin will fully engage itself into the notch and you will not be able to cause the blade to fold on your fingers by spine whacking it. However, it would be unwise to spine whack it with such a force that would cause the rolling pin to be bent.
4. You will also discover that the release button on the side of the SIFU will slide all the way forward when the rolling lock is fully engaged.
5. It took me a while to figure this puzzle out,
but I had to solve it because I had 6 out of 8 SIFUS that I had purchased on which the rolling locks were failing because they apparently were not subjected to proper quality control. Never give up
