- Dec 6, 2013
The collection selloff continues. Still trying to raise funds for my folks so that they don't lose their home.
All prices are to your door/all in
Price includes priority shipping-USA only
I will ship out of the country, shipping cost is on you
I reserve the right to do business with whomever i wish
Pls contact using EMAIL
More pics on request
1. Jimmy lile boot knife doubledged dagger NO DOT- 4" satin blade, stag horn scales, tapered tang. This is a no dot blade. HAs lots of fine scratches due to sheath insertion. I have not usedm carried or sharpened the blade. May have been carried, sheath shows some wear. Beautiful blade, wish i didn't have to sell it. Comes with leather sheath- $685
2. Kit Carson Sm m16- 3" Stellite blade, combo edge. Ti scales, steel(i believe) lockbar insert. I've carried it three times, not used or sharpened it.No blade play in any direction, centered and smooth.
As most know, Mr. Carson passed away in the last few months. He didn't used stellite in many of his blades, this one will go up in value and desirability- $730
3. Crawford Hawkbill liftlock- 3.5" matte finish hawkbill blade. Frame is one piece of 440c, 1/4" thick, milled out. Extremely sharp, no side to side play, little play up(back), but it's a self defense tool, so the hawkbill is made with a little give so that when it cuts, it acts like a claw. Have carried for two days, few snail trails, nothing big. Only negative is that someone tried to adjust(?), move or swith the thumstud, it shows marring on the lug- $385
4.Rmok specs:
CPM S30V stainless steel fighter/combat hand sanded to 400 grit
.220" thick
5 7/8" blade
4 3/4" handle
handle material is double layered brick red and black G10
Professionally heat treated by Peters Heat treating to RC60
Cryo treated to -300 degrees fahrenheit
Will come with custom heavy duty hand stitched leather sheath.
$225
5. Rmok specs:
CPM S30V stainless steel fighter/combat knife stone washed finish
.220" thick
6 1/4" blade
5" handle
handle material is double layered black and OD green G10
professionally heat treated by Peters to RC 60 cryo to -300 degrees
will come with custom hand stitched heavy duty leather sheath
$225
6. Mel Pardue Auto- 3.75" hand rubbed blade. Red micarta linerless frame. One of the lightest blade i've handled. Few marks on the blade that i caught in pics. Has not been carried, used or sharpened-$550
7. Fairall Model #3- 3.75" hand rubbed s30v blade. Swedge has 1/4"ish sharpened at the tip. Tan and blue g10 scales, comes with a set of cocobolo scales too. Has extra hardware too.
Detent is on the lighter side. Requires a firm push of the thumb or flick of wrist to open via the flipper tab. It can also be opened with the dual thumb studs. Has been carried 4 times, cut arm hair to test the blade after i sharpened it. Fairall no longer makes knives, so this is definately a collectible. Comes with soft carry case-$435
8. Crawford Shark 4"- Bead blasted blade, anodized ti frame with ti spacer. I've not carried, used or sharpened. Looks to have been carried lightly by previous owner. Very slight smoothing and a few snail trails on the frame. Very smooth openeing. Solid lockup, no vertical play, very slight play(almost flex) side to side. 95% condition-$360
9. Daniele Serrano folder #2- 3" satin d2 blade. All ti scales/frame. Comes with 2 blades, bothe very sharp! Ti scales have a few light marks from carrying. It has been carried, but not used or sharpened. Needs a wrist flick to open. Slight side to side play, no up or down play. One of the spacing tubes needs to be flared again, i don't have the tool. Comes with case, COA, 2 blades. Very nice and solid blade, it's too small for my hands or i'd be keeping it- $360
4.Rmok specs:
.220" thick
5 7/8" blade
4 3/4" handle
$225
5. Rmok specs:
.220" thick
6 1/4" blade
5" handle
$225
