- Mar 9, 2011
All pieces are new in box. Original edge, never used or carried. Excluding the the police3 see discription below*
I accept PayPal (fees included) but shipping (with tracking) is extra due to the range of destinations. If you have any questions feel free to ask. Not looking for trades Thank you.
Chokwe (C132G) $160 CAD
Steel CPM S30V
Overall Length 8.5 " (216 mm)
Blade Length 3.75 " (95 mm)
Closed Length 4.75 " (121 mm)
Blade Thickness .125 " (3 mm)
Edge Length 3.375 " (86 mm)
Weight 3.7 oz. (104 g)
Handle G-10 / Titanium
Caly 3.5 G10 (C144G) $145 CAD
Steel VG-10
Overall Length 7.625 " (194 mm)
Blade Length 3.5 " (89 mm)
Closed Length 4.313 " (110 mm)
Edge Length 3.125 " (79 mm)
Weight 3.1 oz. (89 g)
Handle G-10
Military(all black) (C36GBK) $170 CAD
Steel CPM S30V
Overall Length 9.5" (241 mm)
Blade Length 4" (102 mm)
Closed Length 5.5" (139 mm)
Edge Length 3.687" (94 mm)
Blade Thickness .145" (3.7 mm)
Weight 4.5 oz (128 g)
Handle G-10
SPYDERCO PARA MILITARY 2 SOLD
Overall Length:8.28"
Blade Length:3.44"
Blade Thickness:0.14"
Blade Material:CPM-S30V
Blade Grind:Flat
Finish:Satin
Handle Length:4.81"
Handle Thickness:0.46"
Handle Material:G-10
Weight:3.75 oz.
Lock Type:Compression Lock
SPYDERCO POLICE 3 $150 CAD
The Police 3 blade is flat-ground VG-10: a high carbon, cobalt enhanced steel that sharpens-up easily and retains its edge. Mid-positioned backlock features a David Boye Dent for added lock security.Has been carried and lightly used, only sign of use is marks on the clip
Overall Length:9.91"
Blade Length:4.35"
Blade Thickness:0.12"
Blade Material:VG-10
Blade Style:Spear Point
Blade Grind:Flat
Finish:Satin
Handle Length:5.56"
Weight:5.00 oz.
BOKER EPICENTER $130 CAD
Overall Length:8.375"
Blade Length:3.50"
Blade Thickness:0.16"
Blade Style: Drop Point
Blade Grind:Flat
Finish:Satin
Closed Length:4.875"
Handle Thickness:0.60"
Handle Material:Titanium
Frame/Liner:Titanium
Pocket Clip:Tip-Up, Tip-Down
Opener:Thumb Stud
Lock Type:Frame Lock
BOKER TITAN $50 CAD
The Boker Titan is a very slender EDC and work knife. It can be carried comfortably even in a tighter pocket, due to the slim profile. The flat ground drop point blade, and the bead blasted titanium handle combines minimum weight with maximum stability. Never used or carried
Blade Length:3.625"
Blade Grind:Flat
Finish:Satin
Handle Length:5.375"
Handle Thickness:0.32"
Weight:4.10 oz.
Pocket Clip:Tip-Up
Lock Type:Lock Back
KA-BAR TDI (model# 1480) never used or carried $50 CAD
Overall Length:5.625"
Blade Length:2.31"
Blade Thickness:0.13"
Blade Material:AUS-8A
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Edge Type
lain
Handle Length:3.32"
Handle Material:Zytel
Color:Black
Weight:5.60 oz.
KA-BAR LARGE TDI LAW ENFORCEMENT W/ ANKLE HOLSTER(model # 1483) never used or carried $90 CAD
Overall Length:7.50"
Blade Length:3.625"
Blade Thickness:0.19"
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Handle Length:3.875"
Weight:6.40 oz.
ZERO TOLERANCE 0561 SOLD
The 0561 features a premium stonewashed Elmax blade with a plain edge and ambidextrous thumb stud. The handle has a 3D machined 6AL4V titanium frame-lock and a G-10 front handle scale. Never used or carried
Overall Length:8.75"
Blade Length:3.75"
Blade Material:Elmax
Blade Grind:Hollow
Finish:Stonewash
Edge Type
lain
Handle Length:5.00"
Closed Length:5.125"
Handle Thickness:0.58"
Color:Brown
Weight:5.98 oz.
*Original owner. Both pieces are new in box, with sheaths. Original edge, never used or carried.*
Original H1 steel (rustproof) SPYDERCO ROCK SALT $300 CAD
Overall Length - 10.5"
Blade Length - 6.75"
Steel - H-1
Edge Length - 6"
Weight - 9.2oz
Blade Thickness - .125"
CRKT RINGED RAZEL $235 CAD
Overall Length - 7.5 inches
Weight - 5.5 ounces
Blade Length - 3 inches
Thickness - 0.18 inches
Blade-HRC - 58-60
Finish - Satin
Grind - Chisel
Style - Utility
Edge - Plain
Steel CPM S30V
Steel VG-10
Handle G-10
Steel CPM S30V
Handle G-10
Blade Length:3.44"
Blade Grind:Flat
Finish:Satin
Handle Length:4.81"
Weight:3.75 oz.
Blade Length:4.35"
Blade Grind:Flat
Finish:Satin
Handle Length:5.56"
Weight:5.00 oz.
Blade Length:3.50"
Blade Grind:Flat
Finish:Satin
Opener:Thumb Stud
BOKER TITAN $50 CAD
Blade Length:3.625"
Blade Grind:Flat
Finish:Satin
Weight:4.10 oz.
Pocket Clip:Tip-Up
Lock Type:Lock Back
Blade Length:2.31"
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Edge Type
Handle Length:3.32"
Color:Black
Weight:5.60 oz.
Blade Length:3.625"
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Weight:6.40 oz.
Blade Length:3.75"
Blade Grind:Hollow
Finish:Stonewash
Edge Type
Handle Length:5.00"
Color:Brown
Weight:5.98 oz.
Steel - H-1
Edge Length - 6"
Weight - 9.2oz
Weight - 5.5 ounces
Blade-HRC - 58-60
Finish - Satin
Grind - Chisel
Style - Utility
Edge - Plain
