Bruzek Knives USA
Knife Maker - Semper Fidelis
- Oct 17, 2014
About Vintage 1926 At’ Sea
Steel Black
$250.00 PPFF Shipped to CONUS
Worn only a few times. has the extra links
Specs
BOX
PREMIUM WOOD BOX
CASE
316L HIGH PRECISION STAINLESS STEEL, INDIVIDUALLY NUMBERED
DIAL
BLACK SUNRAY DIAL AND BLACK BEZEL
VINTAGE WHITE LUMINOUS DOT INDEX & HANDS
GLASS
DOMED SAPPHIRE CRYSTAL WITH ANTI-REFLECTIVE COATING
MOVEMENT
TMI VH31 W. SWEEP SECOND HAND, QUARTZ (JAPANESE)
SIZE
39.5 MM WIDE, 12 MM THICK, 20 MM LUG, 47.5 MM LUG-TO-LUG
STRAP
3-LINK BRACELET WITH QUICK RELEASE (TOOL NEEDED TO ADJUST CIRCUMFERENCE)
WATER RESISTANCE
20 ATM TESTED / 200 METERS (SUITABLE FOR DIVING)
Sea King Watch Co.
Serial Number 61
Worn only a few times. Has the extra links
Specs:
Sellita SW200 movement
All Metal Movement Holder
All 316L Solid Stainless Steel Construction (Includes Case, Screw Down Crown, Case Back, Bezel, Bracelet, End Links and Clasp)
42mm Case with 22mm Drilled Lugs
14mm Case Thickness Including Crystal
6.4mm Signed Screw Down Crown
Lug to Lug (Case Length)- 48.4mm
Tapered Bracelet from 22-18mm with Single Sided Screw Links for Easy Sizing
Solid Female End Links
Heavy Duty 2.0mm Spring Bars
18mm Milled Clasp with 6 Micro Adjustments and Push Button Deployment
Domed Sapphire Crystal with Internal Clear Anti Reflective Coating
Black Dial with Applied Indices and BGW9 Superluminova
Black Date Wheel
120 Click Unidirectional Bezel with BGW9 Superluminova Lumed Sapphire Bezel Insert
200M Water Resistant
View attachment 2506945View attachment 2506946View attachment 2506947View attachment 2506948View attachment 2506949View attachment 2506950View attachment 2506951View attachment 2506952
Steel Black
Specs
BOX
PREMIUM WOOD BOX
CASE
DIAL
GLASS
MOVEMENT
SIZE
STRAP
WATER RESISTANCE
Sea King Watch Co.
Serial Number 61
Specs:
Black Date Wheel
