Reposts with better pricing
Feedback: +20 / =0 / -0
I though this would be great pattern to continue making. Blade steel is 1080 plus from Alpha Knife Supply, a great knife steel with a little bit of chromium and vanadium. I used chain ring bolts for added strength and visual appeal. The handle is natural canvas with a rough sanded finish for extra grip. $155 shipped to your door with a made to order leather sheath and if you dont need the sheath $110.00.
Handle- 4.7"
Blade- 5.2" edge 4.65" .160" stock
Full Flat Grind, Hand sanded satin flats, machine satin bevels
Handle material-Natural canvas Micarta sanded and contoured for grip , G-Flex epoxy with aluminum tubes for pins and lanyard, chain ring bolts added
blade Steel- Alpha's 1080 Plus high Carbon steel, edge quench
In house heat treat and temper.
http://i590.photobucket.com/albums/ss349/jr19703/P1100372.jpg[/IMG
[IMG]http://i590.photobucket.com/albums/ss349/jr19703/P1100373.jpg
Hunter
Handle- 4.5"
Blade- 4.2" edge 4.5" 1/8" stock
Almost full flat grind, hand sanded satin flats, belt finish satin bevels
Handle material-, Nice Cocobolo wood sanded to 1500 then buffed, G-Flex epoxy with Brass pins and lanyard tube
blade Steel Aldos 1084 Carbon steel, edge quench
This knife will come with a natural leather wet formed sheath. $155.00 shipped or without for $110.00
More slicer for your enjoyment. The handle materials are Jade green G10 and black canvas Micarta, perfect for use in the kitchen. Full flat grind with hand rubbed satin finish for easy maintenance by owner. These knifes are made from Sandvik 12c27 razor steel similar to Sadvik 13c26. In house heat treat with digital controlled oven with a subzero quench and a 2-2 hr temper cycles with a projected hardness between 59-61. Knifes specs out at .100 thick by 4.0" blade measures from front of handle, cutting edge 3.8 and 4.15" handle. The knife are very similar the only difference is the black handle has a little taller grind. Even though I think these will work well in the kitchen there are not dishwasher safe.
Each knife with leather pouch style $140.00 with Concealex $120.00, Or no sheath for $110.00 includes shipping within the US.
A couple new knifes one is Sandvik 12c27 with jade green g10 scales and the other is Aldos 1084 with Brazilian cherry or jatoba sealed with linseed. Choose one for $110 with out sheath or choose a Concealex sheath for $120.00 or finally a leather pouch style right or left for $140.00. All prices include shipping CONUS.
Jade green handled Slicer Now Sold Pending Funds
Handle- 4.18"
Blade- 3.8" edge 3.65" .100" stock
Full Flat Grind, machine flats and bevels
Handle material- Jade green G10 sanded to a smooth finish , G-Flex epoxy with brass pins
blade Steel- Sandvik 12c27 stainless with sub zero quench, expected hardness 59-61RC
Wood handled utility or EDC
Handle- 4.0"
Blade- 3.68" edge 3.12" .125" stock
Handle material- Brazilian cherry , G-Flex epoxy with brass pins and lanyard tube.
blade Steel- Aldo's 1084 high carbon steel, edge quench
