- Apr 8, 2016
Don't form a bur or apex with the 50 grit. It's too coarse. It will just rip your edge up and will reduce the edge retention most likely. Just use it to set the angle. Use the 140 to form the apex and bur.
I'd also suggest using cheaper junk knives first and wear those stones in. At least three or 4 knives. Then tape up the blade on your good knives. Use something to act as a lube between the stones and blade. When Cleaning off the blade don't wipe it because your going to scratch it with the swarf.
Also I'd probably go 17 deg though 15 isn't too bad for just slicing.
