Grind an edge onto a small drill bit or allen wrench. That's what I did when I couldn't afford checkering tools. It'll work good enough for one job, anyway.
To make the inlays I Dykem'ed a strip of 1/4" x 1/16" brass and scribed the diamonds on it. I punched then drilled the 1/8" rivet holes in the center of each diamond. Then I cut the 'blanks' off with a hacksaw. I clamped each blank in a smooth-faced vice and filed to each of the 4 lines. Tedious but I got a good result, limited only by my skill. The diamonds aren't all the same. That's part of the charm. Right!
I cut the rivets from 1/8" brass rod. I assembled each rivet/burr set on the knife and traced around the burrs using an X-Acto knife. This left me needing to inlay the brass and me having no suitable chisel. Catspa's idea kicked my butt and I made a chisel out of a piece of bar stock. I just hacksawed a 1/8" x 1.25" piece off, filed it smooth, beveled it, turned the other end round, and stuck it in a dowel. The steel isn't hard at all but it got the job done.
I carefully inlet the brass burrs using a combination of the X-Acto and my little chisel. I made sure of the orientation of each burr, and put a countersink in each one for the rivet to grab.
Then I assembled it and peened it all together. Here's what I got so far. It's a little photo album.
I proclaim it done. I learned a lot during this project - my first inletting, brass work, plenty of file work, marking and layout, peening, and grinding.
This evening a finished sanded the handle, soaked it in oil, and waxed it. I also put a rudimentary edge on the knife - I need some instruction it seems.
