Resharpening / dressing Norax belts
This is probably really old info, but I have only just got around to trying it.
When using Norax belts, I would guess other engineered AO belts would be the same, they cut great when new, but after a while they kind of glaze over and quit cutting so well. There is clearly still grit on the belt, but it stops biting. Previously I have tried using a piece of M2 full hard hacksaw blade to re-dress the belt, but it never worked all that well. Yesterday I tried something else and it worked much better.
EDM slip stones.
They are as hard as the abrasive on the belt, won't leave a glaze, and come in a range of grits which you can match to the belt you use so as not to risk contamination of finishing grits. It just took a single light pass to revive the bite on my really old 400 grit belt.
As I say, this might be old, but I didn't find anything about it when I searched some while ago. Hope it helps someone get some more life out of their belts.
ATB
Chris
I'll have to try that. Norax belts do need to be freshened up occasionally. I jam the edge of a piece of scrap steel fairly hard into the belt and dust flies every where. That dust is older, dull grit and the new exposed grit is back to sharpness heaven.
I have one of the rubber blocks and while it does well on the Hoggers I use, I wasn't sure that it was really doing all that much for the Norax :confused:
tmickley,
I guess I wasn't applying enough force with my bit of M2 since it never really helped much. I was always a bit worryed about gouging straight through to the backing.
