- Oct 22, 2008
I have been testing Resinol 90 for my own use ever since I heard of it . I have a pressure/vacuum tank made out of a piece of 16" pipe. The last batch was a little more promising but not there yet. Following is the last procedure I used:
1. Placed plastic bucket inside chamber , sealed it (chamber) and pulled all the vacuum I could get from my pump( 29.1"hg) and left it 24 hours.
2. Took pump side line off and placed in gal.container of Resinol 90. Opened vac. valve and siphoned enough liquid to cover wood.
3. Let sit for 24 hours.
4.Bleed off vac and put 60psi air and let sit for 24 hours.
5. Bleed off pressure and opened chamber , removed bucket, and wiped off excess liquid .
6. Placed wood in furnace ( do not let touch) and heat to 190 degrees .
( this last batch cooked for 40 mins)
There was a hard resin "puddle" covering the entire bottom , but it did not penetrate over 1/16" . This wood was dry and after taking off small amounts at a time with a disk sander ,
I reached the dry fiber quickly.
Like I mentioned earlier this was the last batch . I learned quickly this shit burns and will ignite if much over 210 degrees. You have to reach the temp slowly , if not it seems "cook out"......? .
I need some feedback from those of you who has had more luck than I have.
