Yes supplied air is quite a bit more complicated than just hooking up a mask to the shop air. To do it right there's a special air compressor to be bought, intake filters, another filter between the compressor and the mask/hood, special mask or hood, special dedicated air hoses (leftover oil on the inside of a used hose...not good) and the system needs to be designed to deliver cool air at the proper pressure. Besides the oil mist issue from a piston air compressor, compressing air makes it really hot, and the output pressure from "just any old" air compressor is more than enough to do nasty things like blow out eardrums and cause air embolism. I have seen a rig that was designed to run off shop air with special filtration, regulation, and cooling, but most supplied air systems come with everything from the compressor to the mask/hood. There are a lot of things that can go very badly wrong if you don't get a system that is properly designed and certified as a supplied air respirator...not something to "jerry-rig" on your own.
