The worst mistake a beginner can make is to announce that every blade he did up to that point is crap.
Ha!... I'm messin'...:thumbup:
Rick, I thought this would be a good place to give you a dose of your own medicineThanks for the testing and saving me even more headache!
Jason
Conclusions:
... 6. If a digitally controlled electric kiln can fluctuate this much, how crazy-off is trying to eyeball it in an open forge? In other words, don't fool yourself into thinking you can nail complex steels in a forge.
Yes, Rick, I should have said "Blade can reach 1800". I have edited it.
As to why the temperature display doesn't show this over heating, there are two reasons:
1) The TC is often encased in a white ceramic sheath, which reflects infrared radiation, and reads the ambient chamber air. Air is not as easily heated by infrared radiation as a metal blade is. The TC is also placed in a position quite a bit away from the blade.
2) The PID which controls the program "learns" as it cycles. The on/off control gets closer and closer as it figures out exactly how long to fire the coils each cycle. Once it gets it figured out, the oven will maintain a very even heat. In the early parts of the learning curve, the PID is like most new drivers. It only knows two positions - "Accelerator Flat on the Floor" and "Hard Brake". During these learning steps, any small mass metallic object that can absorb the heat energy ( like your blade) may overshoot the chamber temp. The readout only shows the air temp. not the blade temp. Page Steinhardt has had to do studies in his metallurgical occupation where they drilled holes in a metal object and placed a dozen thermocouples directly in the object to see how much variation there actually was. It made the company change its HT regimen to allow for fully soaking the oven chamber BEFORE placing the metal object in for HT.
Once you get into pyrometers and PID controlled furnaces, we are no longer talking "simple forge".
.... I made no claims to be reaching its full potential.
Use it in appropriate applications under controlled conditions and compare several different heat treat processes.How do you test "Full Potential"?
Tempilstiks are accurate to 1% of the indicated temperature.The temp sticks are accurate to +/- 100 I believe.
