- Feb 22, 2007
Everyone should have a good strop.
That is all I am trying to say. Stropping on leather with green/black etc compounds, IS sharpening. It is just a lot slower.
I assume CR is starting on the white fine rods at 40° setting. Key bit of missing info is - is this the finishing technique or does one do this from the beginning of the session until the hair popping sharp blade is reached..![]()
Anyone have any thoughts on this remark?
Use a sharpie and color the edge from choil to tip on both sides. If its not coming off all the way to the edge then your not starting to form a burr yet.
Did as you suggested and I noticed that the marker is not coming off the last half inch of the blade on one side. Tried working that area a little more but I cannot seem to hit the edge in that one little spot. The rest of the blade is shaving sharp. Any idea what I could be doing wrong?
If you are using a Sharpemaker,after using the corners turn to the flats and use very light pressure(white stones)then using some cardboard, back of a notebook works well,strop a couple of times then a couple of times on Sharpemaker and repeat.This will get a hair popping sharp blade.
Search for user Jeff Clark. He has a good procedure for removing burrs with Sharpmaker. You basically double the angle by holding parallel to the opposite stone. At this angle make a couple (1 or 2) LIGHT passes per side on clean surfaces of the stones. Then go back and hon 20 or 30 more passes per side. I used this procedure on one of my home made knives and could still cut hairabove the skin after cutting 25' of cardboard with the same section of blade. Very high hardness helps when deburring and holding a very sharp edge on cardboard.
