- Mar 27, 2007
#1 SOLD PENDING FUNDS$185 + shipping Differentially heat treated 1095 blade 3/16" thick wharncliff/reverse tanto style. Blade is 3 1/4" of edge, overall length is 8 1/4" The front edge is sharpened. Shadow boxed/inset handle, bolster is 304l stainless, handles are carbon fiber. Kydex sheath with pocket clip. Very clean piece overall, but just a bit of a bump between the scale and bolster, and there are a couple of deeper grind lines on the front bevel. Fit on the sheath is very tight right now, but I can loosen it prior to shipping if you wish. Price is $185 + shipping.
#2 SPF$195 + shipping 5160 blade 5/16" thick. Curved blade karambit, aggressive hollow grind. 4" blade, 9" overall length. Aggressive curve and sharp hook at the spine. Smooth, low profile carbon fiber scales. Rigged for a large Tek Lok, available mounted for $15.
#3 SPF$185 + shipping 5160 blade 5/16" thick. Straight blade karambit, aggressive hollow grind. 4" blade, 8 3/4" overall length. Straight edge and sharp hook at the spine. Factory textured G10 scales. Rigged for a large Tek Lok, available mounted for $15.
#4 Here is a 5" Medium drop point with swedge. Blade is .32" thick and 5" long, handle is 4 3/4". Olive drab cord wrap. Kydex sheath with belt/IWB/pocket clip is included. Blade is scratching every so slightly in it's sheath (not pictured, but if you are intrested, I'll try to get photos), and it's been sitting around for a while, so I'm reducing the price to $100 + shipping. (from $145 originally).
#5 Also still have a modified tanto forge brute in 1/4" 5160 available. Blade is both 4 1/8", 8 1/8" overall length. Black cordwrap, knife is scratching slightly in it's sheath (can be seen in the first image, and the clip has a couple of minor rust spots, so I'll let it go for $80 + shipping.
SOLD In black for $75 + shipping.
