What I did was remove the large lanyard hole/screw, remove the rear two screws that hold the aluminum scales together, then remove the clip, insert clip into opposite side (for left pocket carry), the clip would not easily fit into opposite side, so I lined up clip with internal slots, inserted lanyard hole/screw and squeezed and tighten, the lanyard hole/screw pressed clip into internal slots, put scale screws back in and did a final check of screw tightness. Whole deal took maybe ten minutes. Hardest part was lining up lanyard hole/screw with clip. Only reason for switch clip was to balance my Lil'Temperance in right pocket with Green Salsa with in left pocket.
