- Mar 17, 2010
kifaru's pics and description of the timberline 3: store.kifaru.net/timberline-3-3700ci-p6.aspx
from left to right: timberline 1, 2 and 3.
The T3 is the smallest of our Timberlines, and is desingned for faster, lighter hunts, but with full overnight capabilities. Like its bigger brothers, it retains the same great features - built-in pockets, stay options and many lash points. The T3 is a narrow, stick-to-you pack that is extremely versatile when it comes to load hauling. A top loader with the rugged simplicity of a drawcord, it can be massively overloaded if needed. The over-the-top strap compesses contents vertically, and extra long lid straps let the T3's lid mushroom upwards. Bottom lash straps let you throw on even more.
- Suspension: WrapTech Suspension System
- Volume: 3,700 (2,100 body, 1,600 ext. pockets)
- Weight: 4 lbs., 9.5 oz.
- Load rating: 100 lbs plus
- Access: Top
- Construction: 500d Cordura body, double layered bottom
- Stays: 24" or 22" composite stays. Subtract $40.00 for aluminum
- Includes: Dedicated T3 top Lid
Built-in Pockets: Are strategically arranged and securely accomodate all your optics and any other equipment you may need "at hand" from the outside of the pack.
Side Pockets: Two large pockets on the sides are specifically built to hold even the largest spotting scopes and tripods. Stabilized by twin compression straps.
Center Pockets: Sandwiched between the side pockets are twin horizontal pockets stacked atop each other. Gear is "ready-to-hand", and the lids open like flaps for extemely easy access. A bungie cord provides compression and extra storage.
- Internal chamber pocket for small items such as keys or a wallet
- Interior pocket sized specifically for a water bladder with an exit port for the hose
Modularity: Hunting PALS webbing matrix: PALS allows secure attachment of our many optional pocket add-ons should you need additional capacity.
- All our packs accept the addition of a CargoChair, used in camp to relax and recline, or in the field hauling gear.
- Multiple compression straps to stabilize any load
Lash points: On the body and lid let you add extra capacity with the many Kifaru modular pockets and accessories. Easily add function and volume from our Hunting, Tactical or even Ultralight (Using our Kifaru Ultralight adapter kit) lines.
Frame & Suspension: Built into this pack, the frame and suspension do not remove. Default stays are lightweight composite, but you can choose aluminum for cost savings. Either way, you get exceptional comfort and a wide latitude for adjustment.
- Access: Top
