- Apr 3, 2013
I purchased a KMFS Vantaedge because I have been getting tired of the way my K03 miss's parts of a blade that has a big curve section plus you need so much other crap to sharpen with a K03 or other guided system's.
From what I found is that the KMFS Vantaedge is very well made and I got their Multiangle Angle Head which allows you to sharpen from 10 to 29 degree's where as the included angle selector only has 15 17.5 20 and 22.5 degree's.
I also purchased their Hover Spring kit which I think was released about 1 year after the sharpener but I could be wrong on that.
The main advantages of the KMFS Vantaedge are that it will always give your blade an even bevel everytime even if you have a blade with a big curve because of the way the sharpener works,with a K03 the angle of sharpening is locked in at the back mast and when the angle changes when you start to go around the curve the problem is the mast doesn't move up and down which cause's the missed or uneven bevel.
With the KMFS Vantaedge the angle is set at where the guide rods and angle selector are connected,if you watch this video at the 4:19 point you can see the rod that goes threw the frame of the sharpener and it moves up and down and that's the sharpener automatically compensating for the angle change.
Another advantage of the Vantaedge is that you doesn't need to adjust anything for different stone thickness's you plain and simply just change to the next stone and you don't have to worry if the stone is thicker or thinner you just sharpen and that's it.
I was also able to sharpen my Manix 2 in about half the time it takes me to sharpen with my K03,I also sharpen my Manix 2 at 15 degree's and with my K03 and I use an angle cube and with the Vantaedge's Multiangle Head attachment the angle was bang on 15 degree's as well or very very close to it.
The only thing I found with the Vantaedge is that you need to press down and not really hard but with firm pressure on the stone holder when sharpening and if you don't the stone want to tip to one side and sharpen with just the edge of the stone,I found that the Hover Spring fixed that problem and I was able to use lighter pressure when sharpening and also the amount of pressure that you would expect to have to use.
The other thing that the Hover Spring helps with is with longer knives and when the rod that goes threw the back of the frame of the sharpen dips down the spring push the rod back up automatically.
The Vantadge also use's ball bearings where the screw goes into the angle selector or the Multiangle Head and the guide rods use linear bearing and the as well as in the backend of the frame of the sharpener where the single rod goes into it it also has a linear bearing,I think the linear bearing are 6x12x35mm and I found them to very smooth.
You also get a 240 600 and 1000 grit diamond stones and I just them once and I couldn't get a very sharp edge with them and that could have been my fault but I'm not sure,I use all 3 of the stones that came with the sharpener then moved to the Venev 800 1200 and 1500 and they were the 100% concentration stones and I stropped with green compound and got a very sharp that I feel sharper then what my K03 produces and I attribute that to the angle always being extremely consistant with the Vantaedge.
The 240 grit diamond stone impressed me that came with the Vantage as far as how fast it removed metal from my Manix 2's blade which is M390 steel,I wouldn't say the 240 grit stone hogged the metal off but it did remove it fairly quickly without chipping the edge or leaving it exessively rough.
I purchased my KMFS Vantaedge from one of their dealers in Finland because if you purchase the sharpener from KMFS directly you have to pay a 21% Vat tax as well and from the dealer in Finland you don't have to pay a 21% Vat tax and they also have free shipping on orders over 200 dollars and mine was shipped to me to Canada via UPS and it took 4 or 5 days to arrive.
This is the upgraded angle selector which KMFS calls it the Multiangle Head Attachment,I also have the hover spring attached to it and it simply slides up and down if it need to be adjusted.
This is the guide rods attached to the stock angle selector that comes with the kit.
This is the stock angle selector not attached to the guide rods so you can get a better idea of how the angle's are set.
This is what the inside of the case looks with with everything in place and the case that comes with the KMFS Vantaedge is best case I have gotten with anything where the case was included,I'm not saying there aren't better case's out there but for an included case it's very very nice and solid and the locks work very well also.
