Well, I finally got it. It's DAMN big. My daily carry is a Benchmade 735, so there's quite a difference here.
I was not impressed initially. There was loctite smeared all over the torx head area of the blade opposite the thumbstud and the blade was very tight. One of the torx screws for the blade stop is missing most of the black plating from the head. The blade stop has good sized contact indentations in it from contacting the back side of the blade when opened. The back side of the blade looks rough too.
Just noticed something else. The back end of the knife is almost perfectly rectangular in cross section, but when you look head-on at the pivot end with the blade closed, the cross section is trapezoidal with the blade stop being the large side and the blade pivot making the other end smaller. Seems like it needs some thicker washers between the liner and the blade. The blade wobbles a little bit more than I am used to. Wish it had larger diameter washers, but the liner lock would get in the way of one side.
Well, I got the loctite off and loosened the blade pivot to make the blade movement easier. I have found that even tightening it too much for easy movement does nothing for the blade wobble, so at least the blade moves easier. This did nothing for the trapezoidal cross section.
I am not impressed. If this knife weren't serial number 001, I'd send it back and ask for another one. As it is serial number 001, I guess I'll hang on to it and put it in the gun safe for my kids...
Steven Reiter,
Lewisville, Texas
