For now I've decided to go with the tube approach to solving the tang length problem. The tube is brass (about 1/4 to 3/8 inch diameter, I think). The end that slips over the tang has been flattened down to allow it to fit over the tapered tang, and two holes have been drilled in it to align with the holes in the tang. Once installed, the pins will secure the tube to the tang, and the whole assembly to the handle (along with the Acraglas epoxy, of course).
I believe this will provide optimal strength and the opportunity to liberate my handle design.
I've already selected most of the pieces that will make up the handle. The main things I'm looking for now are spacers that will enhance the contrast and define the lines better. At the moment I'm leaning toward some flat bone segments I have. The only problem is I don't have enough flat segments. The curvy segments are interesting, but would be much more difficult to integrate into the handle. Might make an interesting challenge. I'll post some pics later, if I get the chance.
- Greg
