- Oct 4, 2010
I work implementing RFID and other related systems. We've experimented in our lab and have found that skimming in public spaces (e.g., streets, airports, shopping malls) at any distance would require so much power that you could warm a burrito in front of the hacker's antenna. Not really practical... Passports are a different animal - the RFID chip can not be unlocked without a key generated by an optical scan of the open passport page. They are pretty immune from casual skimming.
By the way, RFID tags in the HF and UHF ranges don't require full faraday cages for protection - you only need to place the chips in close proximity to a metal object in order to "detune" the antenna and reduce read range to millimeters. A small sheet of aluminum foil in your wallet should suffice. The makers of RFID blocking wallets and accessories are simply looking to cash in on our paranoia.
In addition, the simplest way to "short circuit" an RFID chip is to poke it with the tip of a sharp knife. A little nick on the IC or the antenna will render it permanently inoperable. They aren't very durable when they are outside their packaging material (e.g., the plastic credit card).
TedP
TedP
