What type of angle are you using? Did you strop the edge?
That's exactly what angle would have to do with it. The sharper the angle, in general, the shorter the life. On 1095 Carbon Steel, an 11 degree angle would need to be sharpened more frequently than a 22 degree angle. You might also have a wire edge. If the "razor edge" goes away without cutting anything, I would suggest you have a "wire edge".If I get it razor sharp, what difference does angle and stropping make? Point being, the edge I put on it goes away, and I don't understand why.
From what you said, I would agree with rma100 and RobbW - sounds like a wire edge that is folding over on first real use.
There is a wealth of information on sharpening in the Maintenance, Tinkering & Embellishment forum here.
I would especially recommend the sticky threads at the top, I learned tons from reading those.
You guys don't get it. I'm not cutting anything at. It dulls in my pocket. I can push down on the closed blade, and hear metal on metal. The blade is very (too) easy to push down. I suspect it is hitting the inside. The last inch or so of the blade toward the tip--the part you really use--is what dulls
Gunstockjack:
I'm not doing it on purpose. I just put it in my pocket.
So your going to try and trade a knife with known issues because you don't want to deal with them. Classy.
