High performance makes extraordinary that is the new H50 2.0 Outdoor Rechargeable Headlamp that combines Spot-and Floodlight or dual beam with a max output of 2,000lumens.141 meters long range coverage and 170° wide range flood light specially designed for industrial maintenance,caving rescuing,climbing and mountaineering.
Utilizes 3 x Luminus SST-20 LED(Neutral White 5000K)
Equipped with the customized TIR optic lens, can reflect uniform and soft light
180° tilt angle for different illumination needs
Including one 18650 high capacity Li-ion battery and compatible with 2 x CR123
Built-in the concealed USB-C charging port is effectively protected against the complex outdoor environment
USB-C Rechargeable Approx. 2hours 30 min to fully charge
One button interface controls 5 brightness levels, 3 light sources and 1 SOS special mode
Highly efficient constant current circuit provides a stable output of up to 30 days
The power indicator beneath the switch can indicate the remaining battery power
Rating in accordance with IP68 (2 meters submersible),All-weather applicable
ACEBEAM headlamp is the first choice by China Expedition.
Learn more:
https://www.acebeam.com/wide-beam-led-headlamp-h50
