So now, I need to find out what to do to my ball detent to fix this. Any ideas how to remove microserrations on a ball the size of a few pin heads?
I had a similar issue and tried several oils. None of them helped. Then I got a tip to use a little bit of simple pork lard fro grocery store. The problem went away iMmediatéy.So, I've been carrying a Subcom for a little over a year. It's been a nice knife to me: retains an average edge, flat and comfortable to carry, and clips well.
A problem developed overnight. It's squeaking like a dying mouse every time I open and close the blade! It also developed a bit of friction. I disassembled it, gave it a warm bath, dried pieces off with a microfiber cloth, and put it all back. It worked smoothly... for about 5 minutes. It's back to squeaking and scraping.
So I think to myself, "Well, it probably needs some lubrication..." So I grab some 100% pure silicon, drop a bit inside the pivot, and it works even smoother than before! But once again, after 5 minutes, starts going to noise.So I wash it again, and try some WD40. Same thing. Teflon spray. Same thing. Mineral oil. Same thing. I even try vegetable oil out of desperation. That didn't really help at all.
And yes, it is definitely the pivot. I left it semi-open and closely examined the washers. The blade never touched the frame, yet rocking the blade back and forth did squeak. When it didn't squeak, I got a sandpaper-like sound.
So now I'm stuck with this insane squeaking, and I'm a bit tired of disassembling it, washing it, and putting it back together. Any ideas?
I had a similar issue. I tried several different oils. None of them helped. Then I got a tip to use a simple pork lard from a grocery store. The problem disappeared immediately.So, I've been carrying a Subcom for a little over a year. It's been a nice knife to me: retains an average edge, flat and comfortable to carry, and clips well.
