Since I have been reading so much about how CNC technology reduces the knifemakers effort to just screwing the parts together, I thought youd like to see my new model, the Q-36 ACNC. The ACNC suffix designates All CNC. I hope you like the pictures.
Now, honestly, part of the reason this knife looks so great is that I did sneak in some handwork-I disc sanded the inner surface of the bolsters, and the scales. I also counterbored the bolsters for the screws. I also reamed the pivot hole on the blade so I could get the pivot pin through. I also tapped all the threaded holes in the frames and the clip holes in the bolster. And, I did grind the tabs down somewhat on all the titanium parts, but that was just so I wouldnt cut myself on them. I did lap the frames, but, thats done with a machine, because its the only way possible to make a flexible part truly flat. I also cut and ground the assembly screws to approximately the correct length so I could assemble the knife. I milled in the thumb ramp on the blade, but I cheated and used a manual milling machine (sorry!).
Now, there are a few things about this knife you should understand:
-It doesnt lock open. Fitting the tang to the locking bar is a hand operation.
-It doesnt stay closed. Bending the locking bar, pressing in the detent ball and finishing the face of the lock are all hand operations.
-There is no detent hole in the blade-Another hand operation.
-The clip is not bent, profiled or coated. That would require 7 hand operations.
-The blade profile is not finished. Sorry, thats done by hand, too.
-The flats of the blade have a surface ground finish. Not the dead flat, parallel hand finished surfaces of the normal Q-36. Heck, thats an hour on the disc sander with 4 different grades of paper, with constant measurement with a micrometer, followed by hand rubbing with 600 grit.
-The blade bevels arent ground out either. That would just be more hand work, holding the blade in my hands, using finer and finer belts to produce that lovely sweeping grind, symmetric plunge area and precisely controlled edge thickness.
-There is no scary sharp edge. That would require another 3 hand operations.
-The handle is a little rough on the hand. No hand shaping on a 10 wheel to create the double compound curvature, melted edges and silky satin finish. Boy, Im glad because thats an hour right there.
-The bearing pockets have not been final machined to a 4 micron finish, and arent at the correct depth. So, the knife isnt real smooth when you open it. Oh well, thats a stressful hand operation that requires a lot of effort and measuring to achieve a tolerance of .0005
-There is no logo on the blade, for a good reason. I wouldnt put my good name on a piece of crap. Im a knifemaker, for Gods sake, not an assembler!
Now, Im going to take that mess apart and, after about 6 hours of hand work, I will turn those rough, unfinished parts into this:
Everything that is done to the knife from now through completion is done by hand. My hands!
Stay Sharp,
RJ Martin
Stay Sharp,
RJ Martin
