ok, first off, is the white or the black wire the negative? (i assumed the black, but neither is marked)
second, where on a controller should a heat sync go? (once again, i am assuming atop a bunch of resistors - at least i think thats what they are
they are about 1 cm x 2 cm x 1 cm and look like little firebricks. by the way, i didnt buy a controller, im using the controller from a 1.5 HP treadmill that i had layin around. it seems to work, but it gets REAL hot really fast. guess the heat sync should go on the hottest part (of course) maybe with a fan on top of it?
third, are you both running a pulley off of your motor to gain more mechanical advantage or just running the motor as a direct drive unit?
thanks guys, im very excited about this motor. my previous one i could stop with hand pressure, this one is much stronger.
