Nick I have my 9" set up next to my drill press so I can knock the drilling burrs off my parts to keep them flat and true.
Spencer
Ditto :thumbup: If you're only going to use it for guards, spacers etc. you may be better off going with the flat disk that Rob sells.
:thumbup:
I thought I would let everyone know that I just posted up a web album that shows how to wire a foot switch into Rob's disc grinder....very easy to do. Here's a link to the thread.... Foot switch install
Ditto :thumbup: Mathamatically, (@ 1 deg.), the "cone" you describe would show .0785 relief on each side if you placed a level straight edge across the top center of the disk. If you layed the straight edge "flat" on one side, as Nick described, you would see a .157 (5/32") gap on the other side.
I've had both the flat and the tapered disk. If you're only going to use it for guards, spacers etc. you may be better off going with the flat disk that Rob sells.
:thumbup:
David,
I'm looking at it like a person was making passes... blade horizontal and on the 4.5" radius/centerline... left to right, like on a 2x72... covering the whole blade length. Seems like, without also rolling the blade, top to bottom, a person would get a hollow grind.
I'm guessing I just don't know how a 1 deg taper disc is used.
Mike
FYI........there is a store on Ebay that has brand new Leeson and Baldor 1hp 1750rpm TEFC motors for like $175.
Don't mean to sound stupid "but who is Rob?" Can anyone give me a link to him?
Thanks
As long as we're on the subject... After a LOT of searching, I found a great price on the Leeson 1.5 I use on my Coote at QC Supply... check 'em out. http://www.qcsupply.com/Products/9538.aspx
Shipped super fast too!
-Mark
