- Jun 25, 2001
hey guys
I'm having a problem with a company trying to get 1095 steel that I ordered from them, as you may know from another thread I posted a while back the first time I got blanks cut from them they sent me junk steel,
Mat one of our own here was good enough to test it for me and indeed it was junk steel, no carbon in it and not much of anything else..
the next batch this out-fit sent to me tested out by Matt at what you see below,
which as you can see is not 1095 either
C 0.800
Mn 0.37
P .015
S <0.001
Si 0.19
Cu 0.020
Ni 0.02
Cr 0.19
Mo <0.001
the problem now is,,
the company says they obtained a certificate of compliance for the material that was used in this 2nd order and says the steel sent to me shows in the report, this in it..
0.960 C
0.370 Mn
0.018 P
0.001 S
0.180 Si
0.190 Cr
they will send some of the steel out for a test of there own they said, I'm thinking I want them to do so..
I'd like your thoughts on this?
Matt looked up in the book that 1095 at least in that book does not show 1095 to have CR in it, and the steel out-fit is saying their steel, as you can see, does have CR in it..
it's always said here most of the time, use known steel, then we run into these types of things. do we ever really know what we are getting, we could maybe if we had a 150K machine of our own to test with
what does a good 1095 steel suppose to have in it?
also if the next test comes back that the steel is still not 1095 this means a certificate on it means Nothing to anyone..
I'm trusting Matt's company they are reputable and have no reason to show it any other way than the way it is..
C 0.800
Mn 0.37
P .015
S <0.001
Si 0.19
Cu 0.020
Ni 0.02
Cr 0.19
Mo <0.001
0.960 C
0.370 Mn
0.018 P
0.001 S
0.180 Si
0.190 Cr
