Agreed. Just a wee bit of hyperbole in the OP's claim. Oh, a video desperately in need of views as well.Quite a claim. Utter nonsense, of course. Very nice knives, though.
I have to agree with much of that.Overpriced for sure. I can think of a dozen blades I would rather have. Aluminum handle is hitec materials? lol. Please. The entire frame should have been made for HT'd Beta Titanium with CF inlays for how much they charge. But then again I saw some of their fixed blade prices and laughed. A mid saber grind blade profile that is additionally convexed to the edge makes for a very obtuse blade geometry. The polishing gives it a long lasting finish against abrasion and the 67 Rc will go a long ways. But once this thing goes dull, you will have some fun putting a profile on it. Also the edge is so thick that even with the polish it did not cut the paper so easily. My Spyderco K2 does a better job than this thing at slicing through paper, but it has a proper blade profile for cutting.
The convex grind helps give it superior edge retention. The thickness is what makes the blade so impressive to me. It's not that difficult to get a thin, flat ground blade to be hair popping sharp. But when you acheive that level of sharpness with a thick, convex blade you have really accomplished something noteworthy.I get that the money is in the blade, or so they say. But if you are using a laminated steel for toughness and strength, then why design the profile to such obtuse standards? A tough laminated steel blade could have had a much thinner profile for cutting ability, all that polish is worthless when you make the edge so thick. At this thickness, this blade should have been completely flat ground.
I hear you. That is why I was careful to say the convex grind "helps" with edge retention. I'm sure the main reason is the ZDP 189 steel heat treated to a rockwell of 67.No, the convex grind does not give superior edge retention. Sometimes that "can" be the case, but it's not an accurate general statement. And it really isn't that hard to get a thick convex grind hair splitting sharp.
No it doesn't. The "thicker behind the edge stuff" is nonsense. For two matching edge angles, a convex has less behind the edge than a vee.
It's geometry. It's real.
Yeah....no.
They are certainly very nice and certainly very much overpriced.
