As in edge-trailing? Yes. I alternate strokes from handle-to-tip then tip-to-handle. Yes I eyeball it all, that way I make sure I'm hitting the apex.
Nerves of steel my friend.
This is what I disagree with. I've restored the convex edge without any issue, and the finish still looks brand new. I also find that my edge retention is much better than any knife I have in my collection and I have many; they all see the same type of use.
Steel will be steel, and doing stupid things with a Rockstead will yield stupid results. My YXR7 blade is definately not magical. It definately holds up better than my other knives though.
I'm not arguing, just respectfully disagreeing. My experience has been different.
I was just pointing out an observation that people do indeed have trouble with sharpening as I have seen them, their knives and what was done to them.We thankfully don't have those troubles.
The edge retention on any Rockstead is indeed superb, I have have had great results, but there is that "but"... As for the finish thing though.....
I have found that to keep the geometry correct and in keeping with the original condition it is just not possible to keep the finish clean. You have to put the flat of the knife on the sharpening medium or you're just creating a secondary convexed micro-bevel. (This is the issue nearly everyone has). There is not really anything wrong with that edge but that isn't keeping the "Rockstead edge" you payed for and it leads to problems of some sort sooner or later.
This brings me to my real and main point...... Rockstead are touted as having near infinate edge retention, one of if not the best convex ground blades there is, that as well as one of the cleanest and best finished/coated grinds and blades there are. (that's what you're paying for).
This is in real use not the case, the knives do need sharpened and while not as regularly as a "normal" knife they do indeed dull with use and just can't be kept alive with that strop for long. The resharpening can't be done "properly" with out damage to the finish..... the finish that you payed big $$$$ for because you would never* have to sharpen the knife and so marr that expensive finish. This leaves me (perhaps a little pedanticly) with the question, what then really is the point and what am I paying for ?![]()
I understand what you're saying now, I think I misunderstood you.
However, I slightly disagree stillI infact do put the entire bevel on my sharpening medium, much like sharpening a Scandi grind. I think the method of sharpening depends on the grind, whether it is Honzukuri or Shinogizukuri.
With Shinogizukuri, it would be proper to put a secondary-convexed edge onto it. With Honzukuri, you must use a sharpening medium that will promote a convex shape, yet be tangent to the curvature that is naturally found on the stock edge. If you put a Honzukuri grind onto a flat surface, you can see that the apex is not touching unless you roll it towards the edge. In other words, the bevel will not sit flat like a Scandi grind would. That said, using a sharpening medium that has some flex to it, you are still able to maintain the "Rockstead edge".
This also brings me to the finish. I chose 2000 grit sandpaper so that the mirror finish will still be kept pristine. After some time on 2000 grit, I use the denim strop (with aluminum oxide) which helps further the mirror polish. So any imperfections caused by the sandpaper will be corrected when using the strop.
Damn those industrious cloners!... but those all appear to have a satin finish, nothing close to the Rockstead mirror-polish. It doesn't look near as convincing as some of the other brands I've seen counterfeited.
I guess they blew their 5$ budget on the box... that finish isn't easy to fake, but I guess they might manage it. The second one (as of... now? I'm sure it'll change soon) works up a nice shiny edge, but none of them used the resolution that enables the 'scroll-over close-ups' (?), for obvious reasons. Hand-rubbed satin finish at best.
These guys aren't really trying to pass themselves off as Rocksteads, but some might try to get the high prices, with a bit more time and work. Greed is the deepest well-spring of human ingenuity, as no one likes to say.
This is a very interesting thread. I've had a few questions about Rocksteads and this is helping to clear the air.
Have you guys tried the 3M papers that are sold at Auto-Repair shops? I've seen as high as 5000 grit. They are made from this soft foam-like material, which seems like it would compliment the geometry on Rockstead knives quite well. Also, wouldn't the finer grit yield a higher quality edge (compared to 2000 grit; like BBender uses)?
It might be worth a shot if you guys haven't already tried it.
Excellent thread with lots of good information. From the online photos the knives make relatively "thick" impression. I am just wondering how do these cuts stuff that is thicker (e.g. an apple). I mean - I do not doubt they DO cut, I am just curios whether wedging (knife getting stuck like cutting a carrot with thick knife) occurs.
Don't overthink it...
