Willie71
Warren J. Krywko
- Feb 23, 2013
Chuck, I found similar performance improvements by going harder with 15n20. If used at rc58/59, it's no better than 1084 or 1075. Going to Rc61-63 (the highest I've tested without chipping so far, higher is probably still ok, 62 is definitely fine in the kitchen or in a skinner) and the wear resistance goes way up. The nickel toughens the edge, and it really resists chipping. If you use it like a simple 10xx steel, you leave performance on the table.
Bluntcut, at the hammer in I was at a while ago, it was discussed that the number after temper for testing purposes is less important than the out of quench test. If you have less than Rc66 (for many steels) you have either not brought enough carbon into solution or the structure is messed up, or inversely if heated too high, you will bring too much carbon into solution resulting in retained austentite or excess carbon in carbides, depending on alloying. I did this recently with W2, and there was about a 10f window that gave me rc68. 10f up or down and the results were less consistent, and 20f out, Rc values dropped to 64 or lower. Starting at the most consistent structure will obviously give you the best blade once tempered down to the intended range.
