- Mar 28, 2016
https://www.bladeforums.com/threads/hardness-tester.1527104/page-2Can you give a link to the calibration steps? I'm in a similar boat as you. Thanks!
Post # 21 has a link.
Good luck. Is yours reading all over the place? Or is it consistent but high or low?Thanks, man!
Well, the fact that it's been 30-40 degrees and my shop is uninsulated may be a problem. May have to wait till spring to get a good reading! Manual states it needs to be above 50.
Ha! Maybe next time I have a helper around. I can't believe how heavy and awkward that thing is. Looks like the newer ones have a lighter guage body, but mine about killed me getting it out to the shop.This is 30⁰F? Not ⁰C - that is COLD!!! You're right, the oil is too thick to give good results. Perhaps take in house 'n let sit overnight, then do a few tests?
Thanks for that. I went ahead and picked it up. So, you get your reading after you push the large handle back on step 9, correct?
Everything seems to be working as it should but it needs some cleaning. It doesn't seem to be reading consistently, but there is a bit of rust on the anvil.
