- Jun 10, 2016
Are there any production knife companies the utilize ball bearings such as the IKBS system on their knives? Would you pay more for a ZT or Benchmade if they offered some models that used rollers?
Mhh, I didn't know the Megalodon had them, I might need one just for novelty sake now.![]()
The newest version has them on the full ti framelock. I am not sure about the liner lock or the “megalodon eclipse” which is the framelock with composite front scale.
I got a megalodon in a trade and my friend liked it so much he had to have it. It is an outstanding knife. Buy with confidence.
So how do rollers compare to ball bearings? I assume they're more expensive. What makes them better (or worse)?
More surface/contact area so more stable and thinner profile/height. In turn they don't like force applied in the wrong direction (IE side to side force) and they aren't good for high RPM applications in an industrial setting, although I think in the knife application it'd be negligible.
Thanks. I guess the greater contact area means more friction compared to ball bearings?
That is so cool; in an industrial built like a tank sort of way.
Even with super thin lube I imagine it doesn't win any gravity drop contests but I'm glad they made them and they are out there.
Especially when dirty; oh my gosh!
Do these have seals or are they just open ?
Another question : does anyone make a cup and cone bearinged knife or is every thing just a thrust bearing arrangement ?
Yeah, more friction and in turn create more heat. We have electric drills at work that run at ~35k RPM (and Pneumatic ones that run at 15 - 20k) it makes a difference there, but in a knife flipping out not so much.
Is that reversed? Usually air is faster. At least as far as grinders. What do I know; in my world 3K is fast for a drill bit.Yeah, more friction and in turn create more heat. We have electric drills at work that run at ~35k RPM (and Pneumatic ones that run at 15 - 20k
I think I understand your explanation. Does it mean, everything the same, a knife with ball bearings should be smoother than with roller bearings?
As in when I roll a ball away from me the top of the ball is moving away from me but the bottom of the ball is moving towards me. With bbs in knife pivots it seems like one side of the bb will have to be dragging against one of the surfaces, tang or inside of scale.
While I'm not a mechanical engineer, I agree the advantage to rollers is lateral support. The drag created by the distance the roller is from the pivot would be imperceptible, or so I would imagine.It should be smoother on ball bearings, or at least faster deployment, the roller/needle bearings would mainly provide lateral/side to side support.shinyedges , being a machinist/CNC programmer might have a bit more detailed insight.
