Cliff Stamp
BANNED
- Oct 5, 1998
This RSK was a replacement for one which was replaced due to edge damage (chipping) in light use. This one also had the same problem and during a discussion it was offered for an inspection.
The initial edge had chips in several areas and deformed in others. Under magnification the chips were angular in nature with little to no compression which usually results from contacts off of hard objects which confirms the reported behavior of chipping under light use.
The blade was sharpened three times matching the NIB angle (13 degrees), the sharpened was taken down to x-coarse SiC to remove all damage and produce a uniform and very coarse finish. The polish was then raised up through a series of fine stones ending on chromium oxide loaded leather.
The first trial went 200 SiC, 800 AO, 1000 AO, 4000 AO. Under magnification (10x) the edge had chips which were much larger than the 4000 grit scratch lines, similar to the 1000 AO finish. Additional sessions of honing on the 4000 AO didn't help, they just moved around. Only reached ability to slice newsprint.
A quick check cutting some birch hardwood floring showed the obvious result, the edge failed after just a few cuts and was macroscopically damaged and visibly reflecting light. The sharpness was low, could not readily slice newsprint. Optimally the edge should make hundreds of cuts before being so blunted.
Next round the same initial steps were followed by a black arkansas stone after the 1000 AO. This actually damaged the edge visibly. It actually got deformed on the stone and would reflect light in areas after about 30 seconds of honing. A Paramilitary was then swapped in as a control and it responded well to the same hone.
The final round replaced the arkansas stone with a 1200 grit dmt and the honing was feather light, this was followed by some polishing on chromium oxided loaded leather. The edge could almost push cut the newsprint, but under magnification small chips could still be seen and the edge retention on the hardwood was still low. This is the same behavior as seen on the Skirmish from Benchmade reported awhile ago.
In general nice knife design, the edge is both thin (~0.010") and acute (~13 per side). The handle is a little abrasive though fairly nicely shaped for versatility. The clip is squarish, the new Spyderco clips are *much* nicer.
-Cliff
-Cliff
